Fuel lines on craftsman 32cc 2-stroke weed wacker?
Bravo64
Need some expert advice please. I have a Craftsman 32cc 2-stroke weed wacker, model# 358.791072 that I just replaced the carburetor and priming bulb. I believe I have the fuel lines mixed up. When I press the bulb in, it sucks in and does not spring back out quickly, as it normally would. can someone please advise on the correct way to run the fuel lines?
Fuel goes from the fuel filter in the tank directly to the carb, then from the carb to the primer bulb and from the primer back to the tank.
The primer bulb has a one way valve in it so one side sucks & the other blows
The suck side goes to the carb and the blow side goes to the return line to the tank.
So slip the lines off the primer , dampen you finger & work out which one is what.
motoman
  • / Fuel lines on craftsman 32cc 2-stroke weed wacker?
Thanks Bert, for the information. I know it does not happen automatically.
