Fuel line placement
mcmuria
Replacing carb on LT1050. I forgot to take a picture before removing the fuel line from the pump to the carb. Have not been able to find one. It is obvious that the line goes under carb. Is the line supposed to go between the governor control and the choke control or in front of the choke rod.
Thanks in advance for your input.
You'll need to post a picture of the carb as it is now so we can see exactly what you're talking about , lots of different set ups for different carbs
