thecaptain0220
- Jun 5, 2021
- 1
I have a Craftsman z6000 with a Briggs & Stratton engine. I have been having issues with low power and it eventually shutting off. You can especially tell when you engage the blades. It seems to be fuel related. There doesn't seem to be much fuel flow. At least it doesn't look like it from the fuel filter. If I disconnect the fuel line at the filter and let fuel come out, then reconnect it, it almost always works great after that. It's like it prime initially.
I had another strange thing happen the other day. I filled the gas tank while it was running. I don't typically do this, but I did this time. Once I got it all the way full it suddenly seemed to run much better. Then after a few seconds the fuel level would go down a little and it would run a little worse. Every time I topped it off it would speed up and run smoother until the fuel dropped a little. I'm not sure if this is related to air flow in the tank or pressure or something else. Is there anything related to the tank to check?
I had it gone over last year and they cleaned the carb etc. It seemed to be better for a bit after that and then reverted back this year. I guess it's possible the carb got dirty again with winter storage etc, although I did add fuel stabilizer. Any other ideas would be appreciated.
