Fuel filter change on Kubota ZD 326
JWH23980
I can change one filter but the second one seems impossible to get to for changing. How do I get to the second filter to change it?
BlazNT
I found 1 fuel pump and 1 fuel filter. If it has wires connected to it it's a fuel pump.
Disconnect the fuel line farther up, which will allow you to pull the second filter down to change.
