Bmp4510
 - Feb 23, 2020
- Threads
 - 1
 - 6
I have a 2022 Scag Turf Tiger, 220hrs, with a Kawasaki FT730v-efi engine. Trying to fix for my neighbor. The original problem was he dumped some horrible fuel in it. Took a while to track it down, finally used a separate fuel tank with new fuel and she ran good. In the attempt to fix it prior to discovering the fuel issue, the fuel pressure pump was replaced, fuel filter, spark plugs, air cleaner was cleaned.
After emptying the gas tanks, flushed and vacuumed out three times, the machine ran well. For 15 minutes, the the motor stumbles horribly. Reducing throttle to idle and the engine appears to run normal. To repair this issue, new crank position sensor, new coils, valve lash checked, flywheel key checked, tried running with engine temperature sensor disconnected, tried with charcoal canisters removed from fuel system. If you let the mower sit for 20-30 minutes, she fires up, runs great and again in 12-15 minutes with WOT it will stumble and miss. I gave up mow testing, I just test the motor with the mower in park at WOT. Outside temperature is 75-80 degrees.
i have access the Kawasaki computer interface and software. The engine is not throwing codes. I can turn off #1 or #2 spark plugs, and #1 and #2 injectors. When the motor is missing, turning off either spark plugs (actually the coils) the motor runs even worse. Oddly when I turn off either of the injectors, the motor actually picks up some rpm, but is still missing. Engine temperature is still within normal range. I talked to Kawasaki tech support, and still have not received a good answer.
I’m at a loss and would greatly appreciate any advice or assistance with this issue.
