FS56RC
Scrubcadet10
Moderator
Staff member
One thing I thought of and tried, if I press the primer bulb down, plug the fuel inlet nipple with my finger, and let go of the primer bulb, shouldn't the bulb stay sucked down, due to no air being able to come in?
Hammermechanicman
Press the purge bulb down and then put finger over the purge nipple and release the purge bulb. If it sucks fuel into the bulb the check valve in The purge assy is bad.
Scrubcadet10
Moderator
Staff member
Yep... it's pulling some fuel into the bulb.not filling it up, but fuel is coming in.
Hammermechanicman
Do same test with carb turned with purge bulb on the bottom snd see if bulb fills. Pump it a half dozen times or so.
I think what is happening is the check valve on the purge outlet is bad and the engine runs pulling fuel from the purge bulb then pulls air when the bulb is empty.
Scrubcadet10
Moderator
Staff member
Same result as earlier.
Scrubcadet10
Moderator
Staff member
Picked up a stihl carb at another dealer today, this one is made in the Phillipines..... Trimmer fired right up and runs great.
