Hi guys.
I have a fs250 trimmer, and it fires up good, and runs fine for about 30 min or so, then dies.. sometimes I can pump the primer a few licks and it'll run again for a few min. loosening the filler cap doesn't help. I'm thinking some kind of fuel delivery issue. I pulled the filter out of the tank, and it looks ok. as does the line. thought about a coil issue after it heats up, but I'm leaning toward fuel issue. I suppose it could also be carb related, but runs great - before it dies..
anyone encountered such a problem before?
I'm thinking about a shotgun approach.. change the lines, filter, primer bulb, and filler cap. all are 10+ years old, so it wouldn't hurt, and shouldn't be too expensive..
Whatdaya say guys?
Russ
Whatdaya say guys?
Russ
