frustrated
blackjeepofthefamily
I have a craftsman model 917378480 self propelled mower that i am replacing the helical gear in. Problem is I cant get the bearings off the end of the driveshaft to get the shaft out .Any help would be greatly appreciated. Thanks guys.
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Craftsman Forum. You'll get a better response there. :thumbsup:
They are likely pressed on... and will need to be pressed off... if you have an auto repair shop around, they most likely would press them for you...
You may be able to drift them off using a soft mallet, just don't beat on them with a steel hammer ... :smile:KennyV
