- Nov 29, 2014
- 24,995
Have you tried spraying starting fluid in the air intake and attempting to start it? If so, what were the results?
I have worked on a lot of trimmers (20 or so) including two Weed Eater Featherlites, and not one of them had problems with its crankcase vacuum. I don't have a way to do a valid vacuum test either, and I can usually get them running.
Now not meaning to be nasty here, but if you do not have a vacuum tester how do you know none of your engines had a crankcase seal problem ?
I can get an engine with poor primary compresson to run by adjusting the carb to compensate for the air leaks but it is only temporary . And it is not a fix.
Remember for a stroker to run the seals need to work both under vacuum, or it won't "suck' a full charge in and pressure or it won't "blow" the full charge into the combustion chamber.
5 Signs.
Hard cold starting, Ok hot starting
Poor initial acceleration
Lack of power at full speed
Over reving ( lean burn )
Over heating ( lean burn )
And a sample of 2 is not particularly represantative considering they make around 1/2 million a year.
I give one of the local rehab groups around 50 trimmers a year for them to pull down & rebuild.
Nearly all of them are either Weedeaters or Ryobis at least 1/2 needed new seals.
