Frozen Intake valve 12.5 hp Kohler
Cfs
I am working on a 1987 Ex mark 32 inch walk behind commercial mower. It is a model number 32-12.5kd5. The Koehler engine number is illegible. I can read a Spec of 7275. 390 cc and a serial number 2611504544. Anyway it is a pull start and starter would not pull. I took the starter off and was able to use a ratchet and rotate the engine about a turn and a half and then it will not go any farther. I removed the valve cover and rotated the engine up to where it stops and I was able to observe that the exhaust valve opens and closes, but the intake valve is not opening at all. There was a lot of rust on the push rod for the intake. I have not run into anything like this before I did remove the spark plug and it is not a Hydro lock situation. Do valves ever rust to the valve seats and fuse up? I have seen flywheels rust to coils before and I assume that I need to remove the the rocker arm and attempt to get the valve to move/free it. I suppose that the rocker arm could be rusted to the cam it engages with? This mower has been sitting in a garage for a long time I removed some mouse nesting materials from under the engine shroud...always fun.
Any ideas that anyone can share would be greatly appreciated. I am trying to gather information prior to doing something stupid like forcing the flywheel and maybe breaking something that a little knowledge and patience would have helped me to avoid
Thanks
Chuck
Tiger Small Engine
Thanks
Chuck
Push on the valve spring and spraying with penetrating fluid. Remove cylinder head if necessary.
Cfs
I am thinking that I will have to pull the cylinder head. I will try pushing on the valve first. I am wondering if the valve sear on the intake valve came looseand has the valve jammed in the open position. If it is that...can I use the same procedure I have done on a few Briggs engines of getting the seat in place and using a punch make a series of dimples around the seat to create a ridge to hold the seat in? I am a new comer to OHV heads and issues with them and a complete novice on Kohler. I will look at it later this morning after the rain stops. I down loaded a Kohler service manual from a link on this site. I think it to be correct..looks like it is a Koehler Command vertical 12.5 in hp. Not sure if there is another Kohler engine series that has a12.5 hp size. A lot of the photos look accurate to what I am seeing
Thanks for any and all input
Chuck
