ITS ALIVE!!! I checked out a couple videos and had 2 options to fix the split tube—replace with brake line, or slip over weedeater fuel line and filter. I opted for the weedeater tubing route and she fired up first pull!!!
Not sure if the smaller diameter line will cause problem (I used 1/8” ID). So I had to REALLY heat it up and work it over the split tube, but it went . I figured I’d try that route first as I didn’t want any problems with the brake line falling out etc, or risk breaking the original tube.
Ok, don’t celebrate too early!! Didn’t fire this morning. I think the small line and the weedeater filter maybe getting clogged. Took it apart (again!) andfihured I need to get the original style plastic draw tube back in. So I simply cut the hose at bottom of brass tube(left a sleeve if hose covering rest of tube), and reinstalled the plastic filler tube. Seems to work ok now. In fact, the old belt was ok too, I just finished power raking my lawn. Funny how things go sometimes
