- Sep 24, 2017
- 263
- 6,573
cut the plunger off the solenoid and see if the engine continues to run properly.The wire has 12volts.
I ran a now wire from the battery just to double check the switch. Got the same results.
Clicking and humming sound. After it is on for 20 or 30 seconds it stops making the noise. Weird huh .
I will order a new solenoid and give it a go.
I am running if options!
this part is not required in any way shape or form for the engine to perform safely or properly
