Wife's mechanic
- Sep 1, 2018
- 1
- 7
Read in your manual some say change after 5hrs some 10 and then 10 to 25 to change the first oil. But just because that is their break in oil timeline doesn't mean the motor is all the way broken in. I would at say 50 to 100hrs the motor should be broken in by then. But I would change the oil out before then but not use then synthetic because it is for higher hrs and high mileage engines. I just don't like it and it does seem to lube like it needs to.
The manual for my FX730V said the first oil change should be done at 8 hours.
Went with straight 30 wt and new filter, I'm on a yearly oil change because I don't get the hours mowing all summer.
Change oil and filter every spring.
Dealer recommended 10w-40 Kawasaki oil witch is a semi synthetic, but not sure I want to go with a multi grade oil in an air cooled engine used in the hot summer.
