FX691V
Specifications:
Displacement: 726cm3 (44.3cu. in.)
Number of Cylinders: 2
Bore x Stroke: 3.1 x 3.0 in. (78 x 76mm)
Compression Ratio: 8.2:1
Oil capacity: 2.2U.S. qt (2.1liters)
Maximum Power: 22.0hp (16.4kW) at 3,600rpm
Maximum Torque: 39.4ft lbs (53.4Nキm) at 2,200RPM
Dry weight: 102.7lbs (46.6kg)
FR691V
Specifications:
Maximum Power: 23.0hp (17.2kW) at 3,600rpm
Maximum Torque: 39.5ft lbs (53.6Nキm) at 2,200RPM
Dry weight: 89.0lbs (40.4kg)
