logert gogert
- Jan 11, 2020
- 16
- 546
alright guys, the other day i found a batch of weedeaters on the side of the road. there was one homelite straight shaft trimmer, one murray curved shaft ( i had no clue murray made weedeaters! ), a curved shaft orange weedeater ( its either a no name brand, or the name sticker is torn off ),
a feather lite curved shaft fx26 i believe?
first, i put new gas in them, none of them even primed so i didn't bother trying to start them. ( well, i did try to start them but only for a couple pulls )
so the first weedeater i tried to fix was the feather lite, first i put some gas in the throat of the carb, pulled the cord, it ran for about 3 seconds, okay good, the motors not blown.
i took the carb apart, gaskets were fine, it looked fairly clean, the only place a bit of dirt was on the little internal screen, but not enough dirt to where it shouldn't prime/run, then i cleaned the dirt out of the screen.
To make sure the carb worked i put a little bit of gas in the needle and seat thing ( on the bottom of the carb ) pushed in the needle and the gas slowly seeped down, okay, the carb is letting fuel through, good.
i then completely disassembled the carb, and threw it in the USC. after it was done a few cycles in the USC, i took it out, let it dry, and put in a new primer, lines, filter.
slapped the carb on and, i started to prime it, and after about 20 pumps the fuel started to get in the primer, but the primer would only fill up 1/6 of the way, and very once in a while after you pressed the prime, the primer would completely stop, then 5 seconds later it would start to slowly come back up, uuuuuh okay............?
despite the priming problem i tried to start it, 2nd pull it started, now after it started i wanted to make sure it stayed started so i full throttle, full choke, then flip it to no choke, then flip it to full choke, ( while on the throttle ). then after about 15 seconds of that i let off the throttle to see if it would idle, and of course it didn't idle and it shut off before my finger got to the throttle.
so after that i tried to start it again, i primed it, but this time no gas was going in the primer, and again it would get stuck once you press it in then 5 seconds later it would SLOWLY come back up.
despite that i still tried to start it again, after about 5 pulls this black, oily liquid comes out of the exaughst when I'm pulling the cord, i then think to myself, is it flooded?
i then pull the plug out, and oh YEAH, she's FLOODED, i then blow on the spark plug a bit to dry it off, and then with the spark plug out i pull the cord and as i suspected, a little bit of liquid comes out.
once the plug looks dry enough i put it back in, and try to start it.
then the same thing happens, that black liquid comes out the exaugst, oooookaaaaay..........?
so guys, what in the world is happening? are my rings worn out?
is there something with the carb?
I've done everything in my knowledge and I'm stumped
thanks in advance
-logan
thanks in advance
-logan
