More For Sale/Wanted Trades & Barter
Outboard Motor Parts for OMCs JOHNSON 60,70,85,90,100,110,115,130,150 hp outboards. And others
90 Degree loopcharged years 1985 thru 1998
And some other items. (Outboard Motor parts came from a closed repair shop down in Mass)
Current List as of 06/29/2012
QTY DESCRIPTION New/Used Price Ea. Extended Price
1 Teleflex SeaStar steering Hydraulic Helm Tel Part# HA5418. New $400 $40
3 "Water Pump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2"",Dpth. 1 1/4"" - 6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others.
" New $17 $51
4 Johnson/Evinrude New Stainless Steel Steering arms for outboards ( Will fit other brands) New $50 $200
1 Johnson/Evinrude Alum Propeller, NEW, 14 X 19 #176215, 13 splines fits Johnson/Evenrude New $100 $100
1 Johnson/Evinrude Tilt Pins retainer Bars for Johnson/Evinrudes ( Will fit other brands) New $20 $20
2 Johnson/Evinrude VRO hose & Pump & Sender New $100 $200
1 Johnson/EvinrudeTRIM TAB 327640 OMC New $20 $20
1 Johnson/EvinrudeVRO Kit Part # 438406 includes Pump #175161 New $250 $250
1 Johnson/Evinrude Zinc Skeg trim tab New $20 $20
3 Johnson/Evinrude #323664 Spline Gear New $99 $297
3 Helical Lower unit Gear sets 340490 New $199 $597
1 Johnson/Evinrude New Rectifier/Regulator Kit # 395391 New $150 $150
1 Johnson/Evinrude Ignition Coil Kit # 583737 New $99 $99.00
2 Johnson/Evinrude Ignition coils #582508-0560-0A New $25 $50.00
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 New $85 $170
1 Johnson/Evinrude Voltage Regulator Kit # 173640 New $189 $189
2 Johnson/Evinrude Timer Base Kit #583376 New $200 $200
1 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs New $80 $80
1 Johnson/Evinrude Water Pump Impellers for 85-150 HP New $15 $15
1 Johnson/Evinrude Complete Water Pump kit for ? HP #391391 New $50 $50
1 Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # New $50 $50
1 Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge. New $150 $150
2 Johnson/Evinrude Trim Indicator Gages New $50 $100
1 Johnson/Evinrude lower unit Gasket #286279-2 New $20 $20
1 Johnson/Evinrude Complete Gasket set #139300 fit 85 to 150 HP V4 motors New $50 $50
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $10 $20
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors New $6 $36
1 Johnson/Evinrude Gasket # 359-317955-1 New $8 $8
9 Johnson/Evinrude Gaskets # 194-321727-1 New $8 $72
1 Johnson/Evinrude Gasket # 436-323459-1 New $8 $8
5 Johnson/Evinrude Gasket # ???? New $6 $30
1 Johnson/Evinrude Clutch dog OEM #22683 OEM #319895 New $100 100
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New $199 $398
4 Johnson/Evinrude 90HP-150HP Rod Bearings set New $50 $200
10 Brand New Valves for Inflateable Boats. New $25 $250
1 CMC electric trim gage New $50 $50
1 CMC. PT-130 Transom Clamp Motor Adapter (#13022) New $50 $50
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $20 $40
3 "
Teleflex 18-3056 Impeller Dia. 3 1/2"",Dpth. 1 1/4"" 6 Fins NeopreFits Honda 75 to 150 and Mercs and others.
" New $17 $51
" Used $25
3 #323664 Spline Gear $99.ea. New $99 $297
1 Ignition Coil Kit # 583737 New $99 $99
1 Voltage Regulator Kit # 173640 New $189 $189
2 Helical Lower unit Gear sets 340490 New $199 $199
2 Rubber Exhaust Gaskets New $10 $20
1 Complete 90 Hp Gasket set # 139300 New $50 $50
1 Gaskets # 317914 New $6 $6
2 "used OMC Stator #583669, #583672,
" New $50 $100
2 "used JOHNSON/ Evinrude Stator #583669, #583672,
" New $40 $80
1 Johnson/Evinrude Zinc TRIM TAB 327640 New $20 $20
2 Johnson/Evinrude New $50 $100
2 Johnson/Evinrude fuel fitings New $8 $16
1 Johnson/Evinrude set of new plastic engine throttle connector slides New $20 $20
1 Johnson/Evinrude VRO Oil Tank with hose & Pump & Sender New $100 $100
1 Fuel Fittings Set male & Female old style Merc New $15 $100
1 Fuel Fitting Honda New $10 $10
1 Fuel Fitting Suuzki New $10 $10
Teleflex throttle/shift CABLES OMC Johnson/Evinrude Just $1 per foot. New
2 Teleflex Black 12ft t shift/throttle cable OMC New $15 $30
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude New $15 $15
1 Teleflex Black 23 ft shift/throttle cable MERC New $25 $25
1 Teleflex Black plastic steering wheel New $15 $15
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor. ( May fit other brands) New $40 $40
2 Battery Rotary Switchs New $25 $50
1 pair of Standard Battery to Engine Cables Used $25 $25
2 Johnson/Evinrude electric fuel chokes Used $25 $50
1 Timer Base Kit #583376 Used $100 $100
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $85 $85
1 Johnson/Evinrude pt/pt Relay Box with Cable Used $50 $50
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $50 $50
1 factory service manualfor Merc/Force 9.9 or 15HP outboard motor. Used $40 $40
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $20 $80
2 Stainless Steel Steering arms for outboards Used $40 $80
2 Stainless Steel Steering Coupler brackets Used $40 $80
2 Johnson/Evinrude Ignition coils #582508-0560-0A Used $99 $99
1 Johnson/Evinrude OMC Stator #583672 Used $75 $75
1 Johnson/Evinrude OMC Stator #583669, Used $75 $75
4 Johnson/Evinrude ignition coils Used $10 $20
2 Johnson/Evinrude Flywheel Used $100 $200
1 Johnson/Evinrud Shift/Throttle control Housing $40 Used $40 $40
1 Johnson/Evinrude Plastic Fuel Tanks Used $20 $20
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $20 $60
1 Johnson/Evinrude throttle/shift control Used $50 $50
1 Johnson/Evinrude throttle/shift control, missing a few parts Used $25 $25
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $40 $120
1 Johnson/Evinrude plastic throttle shift handle with pt/pt switch Used $20 $20
1 Johnson/Evinrude plastic throttle handle. Used $15 $15
1 Johnson/Evinrude complete wiring electrical harness with lots of electrical parts from Johnson 90HP V 4 Used $100 $100
2 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs Used $50 $100
2 Johnson/Evinrude Tachometer used Used $10 $20
1 LOWRANCE Blue water Pro Flasher/Paper chart recorder Fishfinder with transducer. Used $150 $150
1 RAYNAV 520 Loran with coupler Used $50 $50
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $100 $100
1 Raytheon VHF/TV Anttena Dome Used $50 $50
Used
4 Factory & Aftermarket Marine Outboard Motor Repair Manuals Johnson, Mercury, Force, Subaru Used $10 $40
1 pair Large indoor/Outdoor waterproof speakers used Used $40 $40
1 pairSmall indoor/Outdoor waterproof speakers used Used $40 $40
Used
2 Two Power tilt motors for older OMC I/O outdrive. Unknown condition need rebuild. Used $20 $40
1 Bronze 11/2 Prop Nut Used $5 $5
Used
1 Fuel Hose with Fuel Fittings & Primer old style Merc Used $10 $10
1 Fuel Fittings Set male & Female old style Merc Used $10 $10
Johnson/Evinrude Fuel Hose with Fuel Fittings & Primer Used $5 $5
Used
Used
1 pair of Alum/Plastic oars for inflateable boat Used $20 $20
2 Child class 3 life preservers Used $4 $8
2 Class I Life Preservers Used $25 $50
1 30 inch USCG Approved Orange life ring Used $45 $45
Used
Used
Used
Used
TOTAL Used 8414
Capt@WickedGoodOutdoors.com
