350boatracing
I have an 07 exmark lazer hp with 56" triton deck
The problem I'm having is I can't get my deck to sit with even pressure on all four chains. I got the back of the deck close to the same height on both sides but I noticed that the chain opposite corner of the height pedal had slack that is until I pushed down on its part of the deck. Then I noticed that the deck teeter totters when I push down near that chain and let up. The pedal has so much side to side and wobble play and when I support the top of the pedal upwards and inwards It keeps the necessary tension so that all of the chains have pressure on them.
Another problem is that I can't get the blades at the right height according to the numbers on the height adjustment. When I have the mower set to 3" the blades are around 2 1/2". I'm hoping the pedal helps but i'll still have the problem of the deck not being what it shows.
Any suggestions please?
