fly wheel bolt size
joboy1937
does anyone know the flywheel bolt size for a kawa FH 721 v. I can't find it in any documentation.
M12 x 30 mm most likely a 1.50 mm pitch. Hex size 19mm. If flange hex head then 18mm; unless, it is a JIS flange head then it is 17mm.
Wish you asked before I finish the engine here but I am not about to take it back a part just to fine out an exact bolt size.
