Floating or fixed deck
Rickcin
I would imagine this is a difficult question to answer without considering the specific terrain ( so I think )
however I am curious to know if a floating or fixed deck does a better job of cutting grass, as far as the appearance of the finished cut ?
I have a 1/2 acre and I would describe it as uneven since there are high and low spots ( within 1 to 4 inches) due to settled areas etc. It I cut the front lawn with the 21 Toro, it seems to look much better that if I cut it with my Sears 42 deck that floats on my tractor.
I also notice that many new commercial mowers now are designed with floating decks, so please let m know what type of deck Generally Speaking provides the better result!
Thanks,
Rick
savageactor7
I been a big fan of 'floating' since before the bi-centennial. We cut low here because we hit golf balls out in the back yard, to do properly that requires a fairway cut.
With the deck lifter springs adjusted correctly the deck, like a scuba diver correctly weighted, a deck will attain a zero gravity effect. That is, the deck should stay where you place it...mostly.
I suppose in theory floating may benefit with the cutting of an undulating yard too...but I dunno for sure.
Our last 3 tractors had to be modified to float with an improvised bale like shown below.
If your yard is not PERFECTLY flat, then I would say a floating deck is better because it will reduce scalping, since it can contour with the land.
