Hello,
newbie to this forum but have run lawnboys since 1950's - my grandfather had both Iron Horse mower and snowblower.
My neighbor just tossed a 5278 and a 7352, so I grabbed them.
Started stripping down the 5278, tank had about 1 inch water, pulled apart the carb and found all the expected muck but not much corrosion.
It is a metal Walbro LMR1, also has 3507 stamped on it [LB part no??]
Cleaned up pretty well, but when reassembling the float, the needle sits high, so that the float bottoms out on the bowl and won't let any fuel pass. Usually a float like this should be sort of parallel to the housing. Its a plastic float, so cannot adjust it. I tried to push the needle seat further in, but won't go.
I haven't found any service instructions for this carb.
Any ideas??
Any ideas??
