Flat Free Front Tires....
I have seen some flat free tires an Norther Tool . I wonder if they fit RSD 36 ?
Had problems with front flats ,could not find hole , air leaking around rim, then filled 1 front with "Slime" , no further problems.
In my humble opinion from my past experience with tires being flat, I find if you have a tubeless tire,
install a tube ... the convenience alone is worth the price. If you have tires with tubes and still get flats ,you might want to consider some 6 ply tires , (not easy to find and pricey too) but then there is of course what you are looking at now, foam-filled tires . If you go the route of putting "sealant' in your tires, if you have someone else breaking that tire/wheel down be sure to mention it has sealant in it because upon removal of tire the sealant usually splashes onto things in the area , some folks NOT knowing get splashed/leaked on and tend
to get somewhat pissed off !
There are flat free tires I saw on Ebay that would fit,if you dont mind riding around on two rocks.
I gotta have my squishy 8psi rubber on the front.
I also have a problems with front tires going flat. I used some slime in them and now they don't give me any problems. I just don't want to be the one that has to change them, when the time comes. lol
If you don’t want too deal with the mess down the road a new wheel with a tire complete is pretty reasonable from what I saw.
