A community had one of those trash days for bulky trash. I drove around in my pickup truck and loaded up. The first item was a mower. I removed the float bowl, sprayed some carb cleaner up there, and had it running within 5 minutes! The oil was gray sludge so I changed that. That one was easy.
Then I got some pressure washers. One had the pump sitting next to the engine with the mounting hardware. I will get back to that one but the engine runs fine without the pump. I can also get the pump to turn but don't know if it is shot. I expect some type of problem since it was partly taken apart and in the trash after all. This is a side shaft Honda GC160 5.5hp unit. The engine at least looks to be in good shape and the oil hasn't been neglected as it was nice and clean.
Then there was a complete unit that appeared to have carb issues. I got it to start and it was spraying water. The oil looked terrible like it had water contamination so I changed that first thing. I ran the unit for like a minute after cleaning the carb and everything seemed fine. I then decided to check the oil just to see how it looked since it was like a milkshake before. The oil fill plug popped out in my hand under pressure and the crankcase was overfilled and pressurized with an oil/water mix. Since the pump is bolted directly to the side of the engine and keyed into the crankshaft, I guess the pump seal must be leaking and then this is going right in past the main crankshaft seal and into the crankcase. Engine seals are likely not designed to account for external pressures like this!
I am wondering if this pump is rebuildable. Is it possible or worthwhile to replace the leaking seal? If so, where is it? I see eBay pumps for pretty cheap these days but wonder about the quality. I am also unsure of how much damage has been done to the engine from being run with as much or more water as oil as lubrication. I am thinking that since I have two very similar setups, I might fix or buy one pump to start. That way if the engine with the water contamination comes apart on me, the other one is still available and I won't be left with an extra pump I don't need. The two pumps I have appear to be different so don't think parts will interchange between those. I might bolt the one pump back on and see what happens. Maybe it is just a stuck unloader. Neither one looks to have been left outside last winter and not winterized. I have picked up plenty of pumps that are split open from ice damage in the past.
Then I picked up a vertical shaft Honda GCV160 unit that was locked up tight as a drum. I figured it was run without oil and figured the pump would be a good spare. I checked the oil and it was dirty but not horrid and at the full mark. I began to wonder about the pump which ended up being frozen up and was also split open from ice damage. I got the engine running fine so will hang onto that as an extra.
Then there was a cheapo Homelite trimmer that just needed a new fuel line. It isn't much of a unit but my GF needs one around her place and it will be fine for her. The hedge trimmer I picked up went out in a blaze of smoke and fire. Apparently there was a good reason it was in the trash!
