triumph65068
I needed this for work so really no information I forgot a lot of thing since I was a kid like what way up on a head gasket metal as I remember was smooth to head and number up I also did not take the rockers apart I just un bolted carefully and pulled the head off and cleaned old gasket off and took scotch guard red and went over it lightly and whipped and put back together making sure that the push rods were seated correctly a little play on the rockers you can spin the motor and when rocker is on highest point make sure it wiggles slightly
