first ridding mower 15 hr briggs dynamark
josh m
every day is a defiant challenge ... i know others have bigger more difficult issues than me ,but those people would say ur cursed to death! but any ways , 15 hr briggs & stratton dynamark $50 ,yes older , will need some work , i like fixen on things..... so runs ok needs a little cosmetic faded red paint looks pink ,cant read some stickers, so on. went to mow dose good , then barring blew on left blade shaft damit here we go , snapped a couple bolts had to torch one off (bearing case) re built both, hell lets give it some paint... black & green left what stickers i could . looks really good. throes belt! damit! well some one has messed with it before , crap, the shaft pulley was welded on poorly like when old wild turkey 101 tells me i can do Anything! haft way through bottle! tighten bolt down ,replaced springs one broke ... working good again cool ,NOT! SHAFT Breaks !!! s.o.a.b!!!! So tare down time. Everything looks good. I think i was the first to see inside sense put together the first time lots of carbon build up, clean it up put $200 Dam part in got anxious usually never good, skipped carb used lg. zip tie to put n rings , might of broke one? painted through it all back together!!! battery shot. grab one out of 87 honda civic, starts up all over the place cant get er dun . Damit. some one says 180" out . ok (I never worked on inside of any engine before) 5 times i pulled that mother off thinking timing was wrong one cylinder wtf . the best i got was a ear ringing back fire. took it to some one, set timing. stats up , all over the place AGAIN, so about had it. he said just readjust carb. now back lawn is about 3' i weed eated & pushed mowed allllll n about 15 hrs (3 days) so back to it . tare down carb bent idle needle , float readjusted , flushed out really good. looking for rings & carb kit local auto parts $30 for rings! Ha.keep looking..........any ideas before i burn it down?............sorry got a little carried away theremower ..jpg
DaveTN
Well, I've had mowers like that and believe or not ... in worse shape and
eventually got them to run. I've got one of those old Dynamark's with a
single cylinder engine. It's like the sea captain story...Would you rather go
on an ocean cruise with a Captain who just puttered around the bay in fair
weather with a nice ship, or would you rather go with one who has been
around the Horn and back several times? Smooth seas do not make skillful
sailors and good, working equipment does not make for skilled mechanics!
That being said, I learned to work on junkers, throw-aways, clunkers and
clankers and some days you win and others...well...:confused2:
