Finding compatible carburetor replacement. Help
ericdraw73
I have an troy-bilt xp self propelled. Think carburetor is bad but when I punch in model in Google I get carburetors that look wrong. Any tried and true parts sites for troy-bilt. Tried one earlier but carburetor wasn't didn't even show up in search. What am in doing wrong?
Scrubcadet10
Moderator
Staff member
you're going to need the engine model information... If it's a troybilt branded engine, you should be able to get the parts look up by searching the Mower model #
if it's a Briggs and Stratton engine, the model information will be on the engine, stamped around the spark plug or muffler, or in some cases with newer engine on a sticker between the carb and cylinder head on the plastic cover.
