Finding Big Rear Wheels
hotajax
The high wheels (12" I think) are not available from Lawn Boy. Is there another source for these? Thank you in advance.
MParr
There probably is. You will need to supply the model number and serial number of your mower for help.
hotajax
@MParr
Dug up the info. It's a Lawn Boy SilverPro Series Model 10252 Walk-behind Power Mower
Serial number 9909383
Nice green frame. Thanks for your help.
MParr
@MParr
The OEM part is unavailable.
They are 14” wheels. Measure the axle diameter. A Craftsman, Toro, or MTD replacement may work. The Craftsman, Husqvarna, Poulan fit 1/2” diameter axle shaft.
MTD will fit 1/2” diameter axle shaft.
The widths will need to be checked with the original wheel.
If your particular mower is self propelled and rear wheel drive, that could be a problem.
hotajax
Found some. McMaster-Carr has them. Probably of better quality than OEM. Yep, 14" wheels. And they're black so they won't show all the dirt like the white OEM ones.
