Fibre washer on axle Model 20055
trooper1954
ILENGINE.....no, this is not the part or the location. These wheels have never been off the mower, and the current position of the fiber washer would be between part # 16 and 17....thats where its located on the opposite wheel.
The washer in your pictures is between the bearing hoc and drive gear, which is the part both I and IL say you need. You can question what we recommend, as you may have more experience than we do with Toro mowers, but I and I’ll bet IL will stand by our recommendations. Maybe someone smarter than us will be able to point you in the right direction.
trooper1954
In the photo I've included, you're looking towards the body of the mower....so the wheel actually goes onto the axle after the pinion gear which is the held on by a circlip......so the wheel goes on from the bottom of the photo
Where you describe the part you refer to is on the inside of the height adjustment plate.....so its located between # 16 and #8 on the outside of the pivot arm....not the inside.
I had no intention of questioning or challenging your experience or help....I apologize if that's how you see it. Perhaps my description of the issue was not clear but the part you're referring to is on the inside of the plate.....the washer is on the outside.Fibre washer 1.jpgFibre washer 1.jpg
Here is a picture of the 110-7191 that we are saying is the correct part. You can compare it to the washer in your picture They look identical to me.
trooper1954
Thanks ILENGINE...yes, that washer looks exactly the same.....I was confused by the location and didn't realize that the same washer was used in a different location.
Appreciate your patience.
@trooper1954 I think the diagram is somewhat misleading They show the washer going on before the adjuster wheel mounting plate, but the washer will not fit over the part that screws into the wheel mounting plate
