Have an old ferris with Kawasaki 25 horse motor. Go out to mow, fires right up, goes dead, motor will not turn over, nothing, it's like the battery has been disconnected. You can fiddle with it, hook battery charger up, yep it's full, look at it kick the tire, go get meter to check the connections. Have meter, try key again, fires right up and runs fine. Go and mow. It has done this the last 3 times I mowed.
