Couple of things which come to my feeble mind. First, I checked the service manual and it calls for a Champion RCJ8Y plug. Second, I know you’ve done a leak down test, but I would perform a compression test, should have a minimum of 57 PSI. I wonder if it is different hot and cold. I know the oil pressure switch only triggers a warning light, but if I remember right I did have one that shorted out the ignition switch when it got hot. Replace it and problem went away that time. Manual says the fuel solenoid and pressure switch connect to the same terminal on the key switch. If that were the case I doubt you would hot spark. IL, I know you have been around the block at least one time, but I’ve got to ask a stupid question, please don’t be insulted. Have you checked for hot spark with an adjustable spark tester and can get it to jump at least 3/16”? I’ll keep thinking, keep us posted. I hope this is not a test, if so I failed.
