- May 6, 2010
- Threads
- 51
- 11,391
Here is one for you guys to ponder. Fresh RN14YC spark plugs, new OEM ignition modules, valves set to .006, and freshly rebuilt carb. Engine will start within about 4-6 revolutions cold, but after running 10-15 minutes won't start with or without choke hot, And will not fire with addition gas dumped into the intake. And the tip of the afterfire solenoid has been removed. And gas is known to be fresh.
