Export thread
FH661V Runs Like Crap
#1
J
JonnyBlaze
FH661V-AS05-R.
I replaced a coil with a new OEM one because a mouse chewed through the old one. I adjusted the gov. New NGK BR4ES plugs, new air filter, new fuel filter. Was running good for awhile and now it's running like crap. I can manipulate it with the choke. Runs better with choke partially on? I took carb off and sprayed out what I could see. Didn't notice any jets? Did I not look hard enough?
#2
cpurvis
cpurvis
Spraying 'what you can see' will not cure a carburetor that needs cleaning.
#3
J
JonnyBlaze
I know. I sprayed all the passages to make sure they were clear. I didn't see any dirt or grime. I think you are suggesting that I need to dig deeper into the carb? I'm here for direction and advice.
#4
cpurvis
cpurvis
Yep, that's what I'm suggesting.
Most people don't have a good feeling for how small critical passages are and how clean they must be for the carburetor to work properly. The fact that using the choke can improve how the engine runs is indicative of a carburetor has has blocked or partially blocked passages.
#5
J
JonnyBlaze
Does this throttle plate look like it's open far enough to you? This is wide open.
B
That is where the air goes in.
What you need to clean s where the fuel goes in.
Instruction should be here http://outdoorpowerinfo.com/repairs/
The service manual with a the numbers & stuff is here http://www.mymowerparts.com/about_us.php
#7
J
JonnyBlaze
I cant get this rubber to seat. Am I going to have to get a new one?
S
shiftsuper175607
Are pulling our leg?
The rubber is upside down.
If not...
Yes, it is probably swollen out of size by carb cleaner.
#9
J
JonnyBlaze
If not...
Great observation, Captain Obvious. Smh.
#10
J
JonnyBlaze
Went and got a new one. Showed them the carb and they said it looked really clean. Suggested that its probably a coil going bad. I replaced one due to a mouse chewing the plug wire in half. Told me to put a spark tester on it and see what happens. I'll do that when I get the carb back together.
#11
J
JonnyBlaze
Got the carb back together. Running great so far.
#12
cpurvis
cpurvis
Does this clerk have x-ray vision or something? He can see the internal passages and tell they are not dirty?
#13
J
JonnyBlaze
He was the owner of the place and I had the carb apart when I took it to him. He was right, so you tell me....
#14
cpurvis
cpurvis
Oh, he's right. After all, he owns the store.
#15
B
Boit4852
Awesome reply! :thumbsup:
