FH641V-BS15 SLIGHT SURGING IDLE TO MID RANGE
Convert
Looking for some input to track down the surging issue .
Just started last week after I refueled the tank. Maybe some crud got through the older filter so-
I changed the fuel filter slight improvement, next i changed the fuel pump -no changes surge continues,
Coils are new, air filter new, sparkplugs are new (last six months). High speed throttle little to no surging.
I think that my next move is a carb rebuild.
Any thoughts?
Thanks
Tom B
Convert
Next move should have been the first move
Surging is usually insufficient fuel to maintain a constant speed
Surging at idle but not WFO = blocked idle circuit
It might need a slight adjustment to the idle mixture screws. These are access after removing the welch plugs covering them. On the following image the needle (PN16187-7002) are under the welch (PN 92066-7009).
Convert
Thank you for your input
Tom B
