I've purchased a Scag Tiger Cub with 1200+ hours with a blown engine. I decided to take on the project of a complete engine rebuild. I cleaned up the block that had 2 broke piston rods and galled crank shaft journal. I took the housing to a local machinist who measured the cylinder diameter and assured me it was within specs for standard piston/rings. He said the crankshaft was toast. He didn't take any crankshaft bearing/bushing measurements in the housing. I ordered rebuild kit with new rods. Bought a used crankshaft on ebay with warranty. I reused ignition coils and valves. After lots of stressful work to get everything back together by the book, I started the engine and was pleased that all seemed fine except it has a whistling/squealing sound coming from the engine. I pulled the muffler, hoping ...then pulled the cover off the flywheel and saw nothing out of sorts. I'm thinking about the crankshaft bearing/bushing that's built into the housing must has been out of spec. ?? Before I tear into the engine again, does anyone have a clue what kind of mess I may find ? The engine seems to run fine otherwise, 100 PSI compression. I've pulled the flywheel looking, pulled the heads off to check gaskets for leak. Is it possible the valves could cause the whistling ? I'm stumped ! I made a video with my phone but don't know how to attach to here.
