addisongravely
- Apr 25, 2018
- 3
- 6
My friends DR mower with a fh500v stalled and would not start last fall. A couple of days ago I sprayed carb cleaner on the air filter and it started. I took it to my house and checked it out and as soon as the engine got warm it would run rough and stall.It would restart after 5 minutes but only run for a minute or so. I noticed the fuel filter was empty. When fuel flowed back into the filter is when it would restart. I checked the fuel pump and it was not pumping much. I replaced the pump, fuel filter, all fuel lines, gas cap, and soaked the carb overnight. Now the fuel filter remains full and the engine runs much stronger, but now it stills stops running after about 25 minutes instead of the 10-15 minutes before and will restart after about a minute and then stall about a minute later and repeat. I did notice if I tip the mower up when it starts to stop rpms pick up for maybe 10 seconds and then it dies. Any suggestions would be much appreciated.
