Ferris is2000z hydro top seal replacement
Travsav
You have a link to the diagram? I couldn't find a diagram with the seals and snap rings
Travsav
Thank you! I don't believe mine has the snap ring
Then it is an older model as this was added in 2013.
Travsav
Startech you are the man. Thanks for everyone's help 😁
RevB
Here's an image with the fan removed. Also unsure the best way to remove that top piece? Pulley puller, pry bar?
Take it to your dealer...
