Ferris is2000z governor linkage diagram 30hp vanguard big block
Andys Tree
  • / Ferris is2000z governor linkage diagram 30hp vanguard big block
I have a 2010 is2000z model5900811 with a 30 hp briggs. I just installed a cam,lifters,sump cover,and a new fuel pump. When I took the governor arm off to replace the fuel pump I thought I would remember where it goes and where the springs go but i forgot. So I'm curious if anyone can find a diagram or a picture of one so I can assemble it correctly. Any help is greatly appreciated. Thank you
Please post all engine numbers, which will help us see what you have.
Hammermechanicman
I have a 36hp big block on my 3100z. Not sure if the same but when i get a chance i will get a pic of it and post
Andys Tree
Engine model is 542777 type 0113-e1 code 09111712 thank you
Andys Tree
Model 542777 type 0113-e1 code 09111712
Hammermechanicman
Taking pic through the rear bars on the mower. Idms this any help?
Andys Tree
I think this will help big time. I appreciate it. I plan on making time to work on it in a little bit and I will let you know thank you
