I have a Ferris IS 1500Z with 148 hrs. on it. The right side steering is not very responsive. Almost no reverse and forward is about 50%. Left steering is fine. I have replaced both hydraulic drive belts, hydraulic oil and filter. I used the proper oil and kept everything very clean when replacing oil. Worked oil in slowly, with both wheels off the ground. Not much help.
When both drive wheels are off of the ground, with the motor off, I can easily turn the right wheel whereas the left wheel offers resistance. Am I looking at a new hydraulic pump or hydraulic wheel motor?
Thanks for any help.
Old Crow
Old Crow
