gfp55
- Mar 13, 2014
- 860
I wasnt figuring on a particularly big operator..i figure 180 lbs-200 is average..machine weighs 2200plus without fuel....check it out before you imply I'm wrong..it's bad enough I thought the guys 1500 was a 5100....
Dry weight IS1500 with 23hp Kawasaki & 52" deck is 1087 lbs. gregjo1948
Ferris 1500z dry weight 1087 lbs with 52" deck, 1222 lbs with 61" deck. With 200 lb operator and 61" deck = about 1422 lbs.
Ferris 5100z dry weight 2178 lbs with 61" deck, 2218 lbs with 72" deck. Whit 200 lb operator and 72" deck = about 2418 lbs.
