Could do these thanks have a vent that's stopped up and causing pressure build up?
I’ll take a few and post soon as I get home. It seems to be holding now with only a few drops since yesterday. I ran it for 15 minutes to get the fluid heated up and circulating. Help things set so to speak.Pictures?
A few pics. You can see the thin plastic of the tank on the bottom where it flexed out of shape.Pictures?
Is that the factory hose and clamp? Looks like garden hose and an automotive worm drive on her. What I am getting at is the hose looks fairly stiff. Any vibes will transfer to that orange seal. And that industrious 90 degree hose barb fitting........A few pics. You can see the thin plastic of the tank on the bottom where it flexed out of shape
Had the same issue on my new Ferris Procut S 61. Always garaged and maintained well. Started leaking after 150 hours or so. Really poor design for a pricey mower! Thought about threading up a replacement bulkhead fitting but couldn’t come up with a good setup. I went with Slomo’s suggestion. Pulled the tank, pulled the grommet, degreased everything and put a small bead of JB Weld two-part epoxy for plastic around the grommet and reinstalled it. Works great! Thanks, Slomo!Is that the factory hose and clamp? Looks like garden hose and an automotive worm drive on her. What I am getting at is the hose looks fairly stiff. Any vibes will transfer to that orange seal. And that industrious 90 degree hose barb fitting........
Yep that is the factory hose based on what I have seen on others. The hose is fairly stiff. The worm drive clamps I have no idea if original. I ordered a new grommet. reinstalled it and have used a few zip ties to contort the hose into a way that doesn't but as much pressure on the tank and grommet. So far it is working. I have an extra grommet and if it leaks again I may try the JB weld route.Is that the factory hose and clamp? Looks like garden hose and an automotive worm drive on her. What I am getting at is the hose looks fairly stiff. Any vibes will transfer to that orange seal. And that industrious 90 degree hose barb fitting........
