Feris 4500z
doddo
Just bought a Ferris 4500Z & noticed it sits a good 1/2 lower on left side. It is sitting on a level floor, tire pressure is same on both sides, suspension springs are both set same. Is there an adjustment to correct this?
KennyV
WELCOME to LMF....
I will assume you are referring to the deck...?
If so there are chains supporting the deck and the chains attach to an adjustable link on the tractor side... You should have a lot of independent adjustment.... or so it would appear... :smile:KennyV
