For the sake of discussion; for a brand new machine that you have sold wouldn't it be nonsense if-for a tire failure the customer FIRST was required to go to the tire manufacturer, for a drive failure the customer had to go to the hydro fluid manufacturer/the drive manufacturer/the filter manufacturer, for an electrical system failure the customer had to go to the wire maker, the fuse maker, the component maker? Kohler probably did not make ALL the parts in their great engine-would you support the customer first having to contact each part maker(carb, spark plug, piston, ignition- etc) for a failure that involved specific components-this is no different from the topic at hand really? for chasis problems it would be the customers responsibility to track down the steel maker, the welding rod maker, the maker of the welding machine??
Walker, Exmark, Scag,- you pick the maker-, the equipment manufacturer selects their components-the equipment maker should be required to take care of issues for the customer without the customer having to argue with individual parts makers.
AND if Walker behaves like Exmark I for one want to know about it.
