i own a featherlite sst25 weedeater. i live on a small budget and have kept my lawn equipment in good shape.
i bought a universal tap and go replacement head but after using it most of the summer it broke the shaft because the replacement head was so big (in my opinion to wide/heavy and hard to start with) i was able to repair that.
i noticed that the oem head was discontinued. and the ones left out there are pricy.
my question is : are there some heads around that are smaller and compatible (thread)
finding various heads on sites it seems hard to determine if they do .most do not tell you the size of the bolt they connect with.
it be great if someone could direct me . thank you
