Fc540V no spark. where should i look.
B Butch41 Forum Newbie Joined Sep 17, 2017 Threads 2 Messages 2 May 21, 2018 / Fc540V #1 Fc540V no spark. where should i look.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 May 21, 2018 / Fc540V #2 Pull off the blower housing and remove the thin wire on the coil. Crank the engine and check for a spark. If you have one then get back to us with the make & model number of the mower as it will be a wiring problem.
