Fastrack SD Hydro slow on one side.
RaptorSD
You might consider setting the forward endpoint of the fast hydro and readjusting the linkage to get equal reverse speed if that's important to you. Otherwise did you measure the control arms on the hydros to see if throw is equal?
MNK
Yes it is important to me and Ye I can do that ... but then the control arms stop in different positions at full speed and ye I can adjust that as well but only for one direction.
Call me **** or maybe I have OCD, whatever, but it is annoying that I pay $10k for a mower and they cant even match the speeds on it.
Yes measured the control arms and the throw is approx. 1.5 mm different
Anyway I sorted it, I extended the operator control arms where the linkage arms attach and, where the linkage arms attach I have slotted the holes on the extender plates to provide fine adjustment for throw equalisation . In doing so the control arms require less travel to meet full speed but this has also allowed me to increase reverse full speed equal to that of forward. So I know have around 12kph forward and reverse, equal speeds at full speed.
Happy camper now.
Thanks all for your input
djdicetn
Happy camper now.
Exactly how are you "measuring" your ground speed to determine the speeds in forward and reverse?? And even more importantly, why on earth would anyone want to go 12mph in reverse??????? ALL hydros are designed for a faster forward speed than reverse(look at any ZTR specs), so why would you tinker with something that is obviously contrary to the manufacturer's design? I can understand adjusting when one side is slower than the other to get the levers equal when going forward, but you have gone way beyond just doing that. IMHO, you are courting danger and may be repairing/replacing your transaxles prematurely:0(
P.S.
The Hustler FasTrak SD's come with HydroGear ZT-3100 trannies as pointed out to you. Their specification is 8mph forward/4mph reverse. My Gravely has the ZT-3400's and they are rated at 10mph forward/4.5mph reverse. You definitely are entertainig damages if you are attaining 12mph ground speed(beyond the "designed" speed). And again....12mph in reverse...REALLY...unusable speed:0(
MNK
:smile:
P.S.
Hi dj and thanks for your input, very entertaining. I bet you can lift heavy things huh ?
So just to clarify:
I use a GPS it tells me 12kph both sides both directions ...... not sure on the accuracy so it may be 11 kph or it may be 13 kph but close enough for my purpose
I said 12 kph not mph , so not sure where you got the mph from. Regardless it is running the same speed in reverse as its big brother the Super Z in standard configuration which is important to us...
The SD comes with ZT 3400 hydros as I subtly pointed out and mentioned to Retired Guns... Not sure where you get your information from but its very reliable huh ?
Explain to me how/why I may be replacing the transaxles prematurely (this should be good) . While increasing the ground speed in reverse is outside Hustler design specs it is not outside the ZT3400 specs, but please fire away!
P.S. I have no idea what relevance your Gravely has to this issue...
I opened this thread to put out there an issue I had and what I did to repair it , nothing more, nothing less. While we may be using the mower outside of manufacturer specs it now suits the purpose and better meets the needs of the specific task it is required to do.
Without knowing what purpose we use the mower for, your comments do nothing but to reflect poorly on yourself. Fortunately,Your HO is just that as it's about as handy as the mechanic that told me the hydros get air in them when you transport .:smile:
Mick
djdicetn
:smile:
So just to clarify:
Mick
I apologize for not catching the kph spec you gave(almost every post about ZTR's speed references mph). Maybe if you check your GPS you will find that changing the setting will give you mph(my Garmin Etrex does)....if that's "important" to you. I'm not much for translating metric to standard. The information I got for the trannies that come on a Hustler FasTrak SD came from the Hustler website(link follows):
Hustler Turf
Click on SPECS.
My concerns regarding the negative impact to your trannies is relevant to the HydroGear specifications for the ZT-3100, not just Hustler's design specs. After all, a HydroGear tranny is a HydroGear tranny no matter what ZTR brand it is mounted on(Hustler does NOT manufacture it's transaxle assemblies). My reference to my Gravely was to point out the differences in the ZT-3100/ZT-3400 speed specifications(my Gravely DOES have the HydroGear ZT-3400's and unless you special ordered it your Hustler has the ZT-3100's). Look underneath your FasTrak SD and write down the numbers off of the HydroGear label on one of the transaxles and post them. I'd be curious to enter that information on the HydroGear website and see which tranny(ZT-3100 or ZT-3400) comes up. One caveat here.....regardless of my opinion regarding possible damages to your transaxles, I hope that if you DO have any problems during the Warranty period that you realize what you have done most likely will void your Warranty for any repairs to the drivetrain. I'll check with my dealer and see what he tells me if I were to have done that to my ZTR. No matter what "purpose you use the mower for"....please explain the conditions that would require you to drive/mow with your FasTrak at 12kph in reverse. We would all like to know what purpose you find in doing that. Hopefully some other "more knowledgeable" users will chime in with their experienced recommendations regarding your unorthodox adjustment to your trannies. Maybe you can teach us all something we didn't know. I've been on these forums for several years and have never heard of anyone changing the reverse speed to match the forward speed. To say that you "put out there an issue I had and what I did to repair it, nothing more, nothing less" conflicts with adjusting the reverse speed to match the forward speed. That's not a "repair", that is an "alteration from specs" and would be considered "something more" than a repair.
MNK
Here you big fella, one more time , just for you !!!
Off the transmission and off the Hustler spec sheet .....
Pretty sure I have ZT3400 hydros on my Fastrack - standard order from Hustler.
Ill leave it at that as it is highly unlikely I could teach you anything, you seem to know it all.
djdicetn
View attachment 22503 View attachment 22504
You kinda cut off the spec sheet at the bottom where the drive specs were...but it "looks like" the 36" & 42" may come with the ZT-3100's and the 48"-60" may have the ZT-3400's. So indeed you have the ZT-3400's on yours(as the picture of the tranny label confirms). Sorry for my confusion, but if you looked at the Hustler website link I gave you....Hustler fails to mention that when you click on Residential/FasTrak SD. Their website only shows the ZT-3100's for that model so I guess maybe you can understand why I would have said that. All that being said.........I wouldn't adjust my ZT-3400's like you did(have you asked about the Warranty not being adversely affected?).
Av8r
Happy camper now.
That's awesome! I wondered how they governed the reverse speed. Thank you for the info, when I retire and get bored maybe the neighbors and I can have tracker races (in reverse). :laughing: Seriously, great info, it's a shame your dealer didn't address it.
