Factory recommended RPM PB-250LN
Sean2202
Greetings,
I was curious what the factory recommended idle speed and wide open throttle speed is of a Echo PB-250LN hand held leaf blower. Also what is the recommended way to adjust if they are not within spec.
Thanks for your input
Sean
geelee
3000 rpm at idle,set with idle speed screw, 6900 at full speed. only way to adjust is with the high speed jet that is plugged off with a plastic insert. if rpm is at 6900 that all shes got captain.
Sean2202
Thank you for your help @geelee
