I’ve replaced the two be,ts with John Deere belts. When I went to adjust them the spring was completely loose, nut was tight and I’m at a loss what to do except put washers behind spring so it will tighten up enough to allow it to give the belts the correct 3/4” slack. Any thoughts?
