F525
Captain Dan
I have an 02 F525 with 320 hrs. that dies as soon as the parking brake was released. I wedged a shim between the switch and the arm from the parking brake to hold the button in and the engine kept running and I was able to move the machine. When I engage the electric clutch, it dies. I suspect the switch is bad. Has anyone else had this problem?
Your problem could lie with the connection to the seat switch. Check it.:smile:
