Fuel exmark walk behind with Kohler CV23s-75580 engine
fzj
I have a customer with a 23hp Kohler Command on Exmark walk-behind that has a flooding issue- gas in cylinders and crank case. is this only the needle valve needing replacing, or is there anything more causing this...like float or fuel shutoff solenoid? has the Keihin BCH Carb, but I can only find complete overhaul kit not just needle valve and gaskets.:confused2:
Did you get it going? Unless you know someone with needle & gaskets, overhaul kit is the way to go & be done with it.
