exmark quest
Did you figure it out? If not, are you sure you aren't getting power to the starter? Maybe it just seems like the starter isn't doing anything because the engine won't spin for one reason or another. I've seen this happen for different reasons: a seized PTO, compression release failure and from piston rings getting stuck on cylinder damage. Can you spin the flywheel by hand?
don't use ohm test, use voltage drop test. It's completely different than an ohm test.
as another poster said, never assume anything. The word 'assume' is an acronym for "make an A&& out of u and me".
