Jaredjward
- Jun 17, 2022
- 1
I'm having a very strange issue and Im looking for help. The mower starts, runs,and mows strong. Then after about 20 mins and usually when I'm stopping to turn around and make a pass in the opposite direction the mower will bog down and shut off. I can start it right back up with no issues and the motor runs fine again. I can then drive back to the garage with the motor running strong. I thought it was somehow overheating because if I let it sit for awhile it will fire back up and mow for another 20 min. I've cleaned the air filter, cooling fins and made sure it has fresh gas and clean deck pulleys and belts. I'm stumped and could use some suggestions. Thank you for your time!
